SOURCE: RCA Opal 8 gb mp3 player stuck in initializing mode
Just gotta reformat it in your my computer menu. Just right click devise then set default to Fat 32 and select reformat and your good to go. However this will erase your data but you will be able to use the player again
SOURCE: RCA Mp3 Opal 4202 is stuck on Initializing. How do I
What i would recommend is for you to reset the device, after you reset the device if you are still having the same problem try to update the firmware...I hope that helps..
SOURCE: player will not initial stays on initializing
Sounds like there is an issue with the firmware. Download the firmware install from here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds. If that does not work then it is likely the player is unrecoverable.
