Cant put new sim card in phone
Puk is a function of your network provider. call him , he will ask your sim no and tell you the code.
Hope it was set a password or a security code on the cell-phone.
And Regarding your PUK code please contact your service provider. The PIN code supplied with the SIM card protects the card against unauthorised use. The PIN2 code supplied with some SIM cards is required to access certain services. If you enter PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider. The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service.
thanks for using FixYa
SOURCE: my sim card is PUKed need puk code
contact your cellular service provider and ask for puk code, they will ask the number printed on your sim card. give them the details and they will give you the puk code. Try inserting that puk code.
SOURCE: Unlock my own sim card,need puk code
its really simple.call your provider and ask for puk code.its normally free of charge.mostly its also available on providers website.go in help section and click on unlock my fone if its there.if not, call em and they will give you the code defo.
SOURCE: The phone needs a code to unblock the whole phone.
Be aware that some users experienced phone freezes after messing up with these codes (use at your own risk). The best thing is to remember the code.
If you are sure you want to continue, follow this steps:
1. Remove the Sim and switch on
2. when you get "Insert the SIM" message
Enter this code: *2767*3855# and let it restart (your phone will be temporarily unlocked)
3. Enter *7465625*638*00000000*00000000#
4. Enter #7465625*638*00000000# (unlocked permanently)
if you just want the puk code contact your service provider they will give it you
SOURCE: My sim card is PUK-locked, I have the Puk code but
We take the SIM card and put it in to an other phone. The other phone needs to be unlocked or have the same operator.
1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
it says i need to turn on my radio for the sim to work but i cant allocate the radio on the phone
