Disk is at capacity but want show files or links saved
The folder might contain a lot of what are called "hidden files"
To view hidden files, press the "Alt" key in your explorer window and go to "View -> Folder Options"
Then navigate to the View tab and under advanced settings select "Show hidden files and folders"
Or:
Go to the Control Panel -> Appearance and Personalization -> Folder options -> View -> Advanced settings -> Show hidden files and folders
That should fix it
SOURCE: running out of disc space
In control panel run disk cleanup also you can delete all but the last system restore point to free up space.
SOURCE: To free hard disk space
100 gb is in single partition, I tried defragment but no luck. I have window Vista is it differs? because I noticed that after restoring the restore point I lost almost 10 GB space. Any solution for this?
thank reply
SOURCE: DVD drive not responding
hi before the system goes to enter the operating system i.e windows or any other operating system you insert a empty blank cd into dvd drive and after you enter into the operating system and check the drive that you can open by pressing the eject button. if not your system will affected by virus you have remove the virus and then go for next step. bye
SOURCE: the dvd is not reading disks you can open it and
If you encounter same problem even after using lens cleaner then try the DRIVERROLLBACK option uinder DRVICE MANAGER. If NEEDED YOU Can also try reinstall/update the driver software of the dvd drive.
SOURCE: Folder Option
Hi Subhash,
That was a great great help.
I just picked up your idea and got my problem solved.
I my case I was not able to select the " show hidden folders" option. So I just changed the registry value from 0 to 1 in the registry editor as per the path given and it works great.
Thanks for your post.
