I want to know where to get these accessories for this machine...bobbins. a zipper foot, a buttonhole foot, a button sewing foot, and a twin needle. I live in Lindsay Ontario Canada
Try these links for parts
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.smscanada.com%2F&ei=CMc3UNHBJuHIiwLb4YHQDg&usg=AFQjCNF1bd7QizlBqng0QrXjuzuktkwHpQ
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=2&cad=rja&ved=0CDUQFjAB&url=http%3A%2F%2Fwww.sears.ca%2Fcontent%2Fspecialty-services%2Fparts-and-service%2Fsewing-machine-repair&ei=CMc3UNHBJuHIiwLb4YHQDg&usg=AFQjCNFL0IMBQACedM4nFcJdR8cj8TZtBQ
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=3&cad=rja&ved=0CD0QFjAC&url=http%3A%2F%2Fvbsimkinssewingmachines.com%2F&ei=CMc3UNHBJuHIiwLb4YHQDg&usg=AFQjCNGpj9kpJyqfZVvFD9NRP1V95GlnYA
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=9&cad=rja&ved=0CGMQFjAI&url=http%3A%2F%2Fshop.sew-classic.com%2F&ei=CMc3UNHBJuHIiwLb4YHQDg&usg=AFQjCNE5kvfq-51mcGnnW9DaDXn2-HN-0g
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin: wound with uneven tension. Try taking the bobbin, rewind that thread onto another bobbin and wind slowly. make sure the thread feeds onto the new bobbin evenly.
upper thread: catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help. we can troubleshoot some more!
