20 Most Recent
Euro-Pro Shark 9110 Sewing Machine Questions & Answers
Why does the bobbin case pop out and jam the thread?
First check that the thread in the bobbin is facinf the correct way. Then check tension on top. Also check to see if you have the same thread on top and in bobbin. Also needle and material can cause the bobbin to jump. Make siure that the needle thread stays where it should, if one of the threading sites come undone this can cause bobbin jump too.Hope something here helps.:-)
How do i raise the feed dogs on my singer 30215 machine
Slide of the the little table with the accessories in.There is a feed dog adjustment lever at the back of the machine. sliding the lever to the 2 filled in arrows pointing down, will lower them and the 2 filled in arrows pointing up will raise them. The feed dogs will not rise up if you do not turn the hand wheel manually, even if the lever is slid to the right.You must make a complete turn of the wheel to raise the feed dogs.
Best wishes.
Auto needle threader
I have had problems with this too. But you can get them from Euro Pro about $10.00
All of a sudden the needle won't pick up the
There is a screw that holdsthe linkage together that rotates the bobbin holder, that screw might beloose. To replace it requires taking both the front and back covers off of theframe since the bobbin holder linkage is in the rear behind the needle area. Becareful to insure that the plastic toothed "rail" that runs thebobbin holder is positioned properly or it may break off a tooth. Once you replace it, it will catch the threadagain.
AV
