The tv was a gift over ayear old now,no warrenty. its impossible to watch a show it freezes for long periods of time. it has only tuned in a few channels when the other tv in the living room is fine. now its turning off and on on its own, the please wait signal is in a different language, when the tv turns on the yellow light flashes-and the green light stays on while off, its even starting to shut off while playing the dvd player.....GRRR HELP?
SOURCE: Insignia 42" lcd, lost power, turns on and than right off again..
its the problem of ic 343 and ic 344 on the main board which needs replacement as if you are familiar with reparing you can try to check out main board.if not call the repair person. as its advisable.
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
SOURCE: cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
SOURCE: I have a 37 inch Insignia flat screen tv. This
This unit needs to be tested in a service center because it has problems with the operation of the video card. This could be caused by a loss of voltage supplying the video card from the power supply card. Or a failure on the video card itself. You can purchase parts for unit from Best Buy Parts at !-888-237-8289 and get customer service at 1-877-467-8289. You should get an estimate from the service center, That should tell you which parts are bad and then you can proceed from there. If the prices seem too high for parts and labor from the service center, try buying the parts yourself and have them install them for you. You should try to check the prices on the parts , just to make sure you are getting a fair deal.You can do this by getting the part numbers, you should ask the service center to provide the part numbers needed if they need to replace the power supply board or video board and with your model number of television check out the prices and availability at the Best Buy Parts website.Of course if the television is still under warranty send it in for warranty service. Hope this helps you with your problem.
SOURCE: Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Thank you, i appreciate the advice
