You need to run chkdsk...
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Fragmentation makes your hard
disk do extra work that can slow down your computer. Removable storage
devices such as USB
flash drives can also become fragmented. Disk Defragmenter rearranges
fragmented data so your disks and drives can work more efficiently. Disk
Defragmenter runs on a schedule, but you can also analyze and defragment your
disks and drives manually. To do this, follow these steps:
Under Current status, select the disk you
want to defragment.
To determine if the disk needs to be defragmented or not, click
Analyze disk. If you are
prompted for an administrator password or confirmation, type the password or
provide confirmation.
Once Windows is finished
analyzing the disk, you can check the percentage of fragmentation on the disk in
the Last Run column. If the number is above 10%, you
should defragment the disk.
Click Defragment disk. If you are
Disk Defragmenter might take from several minutes to a few hours
to finish, depending on the size and degree of fragmentation of your hard disk.
You can still use your computer during the defragmentation process.
Notes
If the disk is already in exclusive use by another program, or if
the disk is formatted using a file system other than NTFS
file system, FAT, or FAT32,
it can't be defragmented.
Network locations can't be defragmented.
If a disk that you're expecting to see under Current status is not showing up there, it might be because it
contains an error. You should try to repair the disk first, then return to Disk
Defragmenter to try again. See Check your hard
disk for errors for more information.
also "hibernate" the computer instead of "shut down"
