SOURCE: bosch GSB20-2RE drill
check out toolpartsdirect for electrical diagram.
the think its electrical problem
SOURCE: Drill Started Smoking Now won't run
An overload could not cause catastrophic failure. Try contacting the manufacturer via internet and ask for their info on your product. If useful print it and bring back to the tech. DO NOT GIVE IN TO THEIR BULLY TACTICS. The 1st rule of any business is "The customer is ALWAYS right" Bring the tool back to where u bought it and demand a full refund.
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
SOURCE: My reversible power drill can only work in anti clock direction
i'm afraid you have to replace the switch...
SOURCE: my chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
