None
Not really sure on that one but on most first you will need to remove screw around handle that opens the door that needs to be removed. also should be screws underneth handle that pulls door shut that you will have to remove and in some cases . check around edge of door panal for more screws and if found remove them also. once all screws are removed you will need to pry on door panal slightly because there are clips behind panal holding it on. in alot of cases the clips break when removing panal but dont worry the can be bought at your local auto parts store and are very easy to replace. I usually use something flat like a small stiff putty knife to help pry door panal lose. this helps insure that you dont break of crack the panal. after all clips are off simply unplug wire connections and door handle linkage and your done. .....hope this helps and good luck
SOURCE: remove door panel
Remove the screws and lift up. There aren't any screws behind the window switch, it is screwed on from behind. There is a hidden screw behind the lock slider.
SOURCE: Im trying to get the door panels off my 1999
There are a few screws which need to be removed, one under the map compartment (bottom of door ) one behind cover at door handle, once these are removed pry door panel out from the bottom up removing it from the clips, once this is complete lift up and remove entire panels off lip at top
Testimonial: "thanks for your help"
SOURCE: need to remove inside door panel on drivers side
just pop out the triangle piece from the top at the top front of the door panel with a flat head screwdriver. Then simply pop out the door lock cover from the aft side and the door handle cover from the aft side as well. Then pop up your cap containing the auto door locks and windows and disconnect the cannon plugs. Then just remove 2 screws (1 from under the door lock/window cap and one just insde the door handle itself. You'll then life up and towards you to remove the panel. Don't pull it too far out because you'll still need to disconnect the speaker cannon plug and pull out the door open light at the bottom aft of the panel. You can then set the door panel off to the side.
SOURCE: no power to passenger door window or lock, drivers
I know this sounds strange but I believe the problem is in the drivers door. This is where the master switch is and controls the other doors. Have it tested or replaced. Hope this helps. Good luck.
SOURCE: How do I remove the driver's door panel on a chevy 2007 nbs?
open door pull ruber boot back on door side unplug wire connections snap lock release on con pull pins pull door
