I have a '97 Jeep Grand Cheorokee with a unique AC issue (at least to me) - When the vehicle is started, the AC works fine - blows nice and cold. Then after about 30 minutes, the cold air stops - fan still works fine - just no cold air. The unit has been fully charged - no leaks. Once the Jeep sits overnight, the AC works fine again - only for about 30 minutes. Is there some kind of thermo switch that is 'overheating' and needs to reset? Any ideas? Thank you
SOURCE: heat/ac not working on 2004 Jeep Grand Cherokee Limited
look for Main A/C relay, look for fuses, or go to a/c shop and have gas check out, perhaps leaks, perhaps evaporator, perhaps condenser, but start for relay box on front passengers side, or fuses on same side
SOURCE: 2005 jeep grand cherokee ac blows cold only on drivers side
I agree, these vehicles have a problem with the blend doors and since the accuators hit the door when it opens and closes, it breaks the doors. and it's a huge job to replace them.
SOURCE: Air Conditioner works intermittently
It could be your low pressure cycle switch is going bad. Check the connection to the switch and it's is located on the A/C Accumulator. The other thing to check is the A/C relay and that is located in the glove box. There is a panel in the glove box that say's relay, there is three relays in there and one of the out side relay's out of the three is the A/C. can not remember which one it is. The middle relay is the fuel pump and the other one is the third break light. Switch the two out side relays and see if your A/C get's better. the other thing too is if the R134a is just a little low, and needs to be topped off. Good luck and hope this helps. if your going to try to recharge the A/C system your self, keep in mind not to over charge.
SOURCE: 2000 jeep grand cherokee laredo air conditioning
make sure nobs are not broke pull them off check for cracks if not the your blend door might be sticking
SOURCE: 2000 jeep grand cherokee air conditioning
sounds like the clutch field on or bearing on the front of the compressor went bad take a closer look at the pulley on the comp. and see if there is any debris or melted plastic coming out behind the pulley,if so the clutch,field and bearing should be replaced,hope this helps
