The bucket light is blinking but its not full and the humidity setting flashes between 24 and "ch". It's worked great for about a year but suddenly this is the issue and it won't allow me to change anything.
SOURCE: bucket full light flashes, humidity
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: Not running. Blinking red light for bucket full.
Leo, have you removed and emptied the buck and reinstalled it? If not, that's the first thing you need to do. If you have already done that, remove the bucket and if it's equipped with a float valve in the top of the bucket, make sure the float is not stuck in the UP position. If it is, jiggle the arm of the float, so that it will return to the DOWN position.
If not equipped with a float valve, when you reinstall the bucket, be sure that it fits "squarely" from top to button into the holder.
NOTE: Before attempting any of the above, turn the unit OFF and unplug it it.
Hope this helps you troubleshoot and solve the problem.
SOURCE: Not running- CH 24 code on
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
SOURCE: The humidifier says the bucket
heatman101
