Preinstalled
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
SOURCE: prestige remote starter fell in bowl of water
Wasn't the unit hooked up already? You can't plug it back in? I'm still trying o picture the dropping into a BOWL? of water???
Give me the model and I can give you color codes, but if the wiring is still in tact you shouldn't need to rewire. Let me know and I'll help you out.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: location of prestige remote start
if the signal lights blink when you try the remote start take your truck to advance and have them check for codes tell them you want a code check and if there are codes ask what they mean and have them cleared my 2007 silverado did that if the check engine light was on
SOURCE: how do auto remote car starters work?
Usually the car start system has a "Valet" switch hidden somewhere under the dash or in the glove box. This is used to disarm the system for when the vehicle is serviced. You will have to locate and turn the switch on, some units have a small push button. In either case it is a good dea to locate it for future use.
SOURCE: How can I disarm a prestige car alarm system
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
