Your problem is probably the temperature sensor. It can be found on the intake manifold, below the thermostat housing.
murf427
SOURCE: Not accelerating when stepping on the gas
throttle position sensor would cause this. Is there a check engine light
SOURCE: 1996 Jeep Grand Cherokee stalls when brakes are applied
My 2000 Grand Cherokee had the same problem, without all the sputtering, it would just die approaching a stop. We could only keep it running by slightly pushing down on the gas petal when coming to a stop. I replaced the Throttle Position Sensor, but that didn't change anything. A new mechanic I found replaced the Idle Air Control Valve, and we've had no problems in a week.
SOURCE: my car starts and then dies
sounds like a security issue they installed a factory security system which will prevent the vehicle from running unless its reset go to passenger door lock turn key twice it worked for me after chasing other problems for a few hours
SOURCE: 1993 jeep grand Cherokee...stutter in drive at low rpm
Hello;
Have you checked your fuel pressure and volume? You may not be getting the ful sufficiently to the injectors. Also, change your fuel filter if you haven't already. Is the check engine light on?
Thanks;
Rich
RPM Northwest
SOURCE: 99 jeep cherokee sport 4.0l 6cyl voltage will go to 19v
The problem sounds intermittent, if you put volt meter on the battery while it is at that 19volt mark/reading(on the gauge cluster) you will be able to see if it is true. If your alternator is really charging over 16volts the lights should be getting brighter then usual and/or they are burning out. Find out ASAP, if the alternator has a defective voltage regulator, it needs to be replaced. Prolong use will damage components.
HOT/WARM START ISSUE
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
