This JD 115 with B&S engine was running OK a few weeks ago, now it won't start. Have done the following: New fuel filter New Fuel pump Blew out fuel line to gas taank Installed carb kit, set low speed valve at 1 1/2 turns out Checked little actuator on bottom of carb bowl - works OK in/out with ignition switch turn on/off Checked for spark - good. Installed new plug anyway - spark ok Sprayed WD 40 into cylinder. It then starts immediately and runs for several seconds and then stops This mower has me stumped ... Have run out of ideas Help anyone?
Had a motorcycle that did this, found a tiny piece of rubber, probably from a seal sticking out of the carburetor jet, sounds like a jet, they have tiny holes and easily plug.
Fuel related if it starts and runs with a squirt
take fuel tank off and clean it out
have to re check the carby
float , needle or float level clogged jet in carby
SOURCE: Model 180 John Deere garden tractor won't start
*cyliniod sticking... try banging on it with the blunt end of a good heavy screw driver / or the handle of a hammer. might free up the contacts, or it might be too rusted inside...
*yes to the first part about starting fluid...the starting fluid should have fired off the motor for a few seconds...so since you didnt get anything after this, it sounds like your not getting adequite fire to the cylinder (s) .
i would try a new spark plug since that would be the cheapest thing to start with first.
SOURCE: Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
Squirt some carb cleaner into the intake. Had the same problem with mine and it fired right off. Must've been something down in the line.
