I have a Jenn-Aire built in double oven about 7 years old. It is working fine except the display on the top unit has grown VERY DIM recently. Indeed, I can barely see the time displayed and the data that displays while the unit is in operation (temp and so forth) is barely legible now because it's so dim. Any suggestions?
John in New Mexico
SOURCE: jenn air oven display
Temporary solution, rapping on the display brings it back to normal for about a day. Certainly not a permanent fix, though.
SOURCE: Digital display is very dim
The most common cause is the failure of an under-sized capacitor on the display unit. Look at the board under the display, the component is labeled C3. It is a small cylinder with the label 68mf, 35V on the side and is attached by 2 small wires. It will probably be a little burnt or have small brown drips like syrup under it. You can buy the component at Circuit City or anything like that for about 75 cents. You need a pencil soldering iron (about $10) to remove the old part and put the new one on. If you can drip a candle, you can solder these 2 wires.
SOURCE: dim display.
The display sits on a circuit board. Pull the board out and replace capacitor C3. It is 68 micro farads. I used a 47 from Radio Shack and it works great. If you can find a 68, that would be ok too, of course!
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
I too have the same problem and we replaced the display about a yr. ago for $350. It now needs to be replaced again!!! This time 400.! Clearly something is wrong with this model.
I have the same problem. What I have found online it is the electric clock assembly. It need to be replacesd partsselect.com $181.81, applianceparts pro.com $159.05. Ten minutes to change
