Played a blu ray movie last night, now that same disc, as well as any other disc will not play. Display reads can't play disc.
Once you have found that Blu-ray player won't play Blu-ray disc, the first thing is to have a further check on your Blu-ray player because this is one of the main reasons that may result in the failure.
If you have checked your Blu-ray player and it turned out to be perfectly set, then the reasons for the failure may fall to the Blu-ray disc itself.
You can check on this tutorial for some more details;
Why Won't My Blu-ray Players Play Blu-ray Discs
See the cause and remedies:
Does not play
disc
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
SOURCE: My Sony DVD portable player DVP-FX820 Will not
there is a problum with lense assy so please clean the leans & then try if the condition same then replace the pick up
SOURCE: ratatouille blu ray disc stopped playing
hi try to use the lense cleaner dvd... it will clean up the dust... then ur player starts to work..
thank u
SOURCE: When I try to play a Blue Ray DVD movie I get the
Use a q tip with a little bit (not dripping) of rubbing alcohol. Eject the tray,unplug, look for laser,you may have to do a little bit of disassembling,but have no fear if you have a digital camera at hand. Use the q tip and gently spin it between your fingers and lightly press against the laser lens. Let the lens dry and look for streaking,if it streaks,youre using too much alcohol. After cleaning,test with an audio cd,then regular dvd,then blu ray. If it works awesome,if it doesn't then the laser is most likely burned out.
SOURCE: I have the Sony BDP-BX2 version 006. My last 8
hi,
may be of upgrading problem or all blue ray disc won't play in all players. if a blue ray plays on a blue ray player may will not work in another one and vise versa. not all the discs some one.
ok
Testimonial: "Sounds like guessing all over the board. The same Blu-Ray movie (new) from 2 different stores. One plays GREAT, the other won't even be recognize. "
Display reads can't play disc on any type of disc inserted. I've tried all forms of disc media, and get the same result. Tried a lense cleaner and got the same display reading.
