20 Most Recent Sony BDP-S300 Blu-Ray Disc Player Questions & Answers
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Sony BDP-S300... | Answered on Jan 19, 2020
As with many Sony models, there is no way to hack the region coding on your model, sorry. This applies to both the DVD and Blu-Ray region coding.
But if you have a Blu-Ray drive fitted to your pc, you can use a program like DVD Fab to make a back-up copy of your Blu-Ray disc which strips out all of the region coding and copy protection. The copied disc can then be used on any machine.
Note that this may be illegal in your country; it's up to you to ensure local legal compliance. It's also illegal in the UK where I live, but in practice there's no problem as long as I don't use the software to distribute unlicensed copies and provided that I destroy/delete copies when I dispose of the original disc.
Sony BDP-S300... | Answered on Dec 17, 2019
Try to update the firmware on the player by going to this website http://www.blu-ray.com/firmware/firmware.php?id=10 the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
Sony BDP-S300... | Answered on Dec 11, 2019
whats the unlocking code for.. to play any reagion blu-ray.. if so lemme know.. thedeadinme@hotmail.com
Sony BDP-S300... | Answered on Dec 05, 2019
http://www.hometheaterinfo.com/dvd3.htm
http://www.dvdregionhacks.com/
I'm sorry to inform you that the Blu-ray player requires the remote to playback the blu-ray movies. You can playback normal DVD video disc which has auto play option. In order to go though the Menu items before start playing a Blu-ray DVD. Hence Remote is must..
Thanks for understanding..
Sony BDP-S300... | Answered on Nov 14, 2019
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc.
I hope you're clear with downloading the update from support page.
Once you download and save the file in the folder in the computer, you can double click the file to extract.
You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder.
Most of the customers will be making mistake here after...
We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image.
I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software.
Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option)
Navigate the extracted .ISO file we saved in the computer.
follow the onscreen instructions.
Insert the disc when ever Nero asked to insert
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Sony BDP-S300... | Answered on Nov 13, 2019
Id the disc clean of debris dust and scratches? Cleaned the unit aswell with a blue ray cleaning kit? Please do these things, if you find this helpful please use Fixya when rating Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sony BDP-S300... | Answered on Oct 11, 2019
I had the same problem with mine, if you haven't solved it by now, you need to do press these buttons in this exact sequence:
1) select radio
2) press "Band" to change from AM or FM to FM2
3) press preset #5
4) press volume down twice
5) press volume up twice
The screen should then display something along the lines of "the CD eject lockout has been disabled" and your eject button should then with properly
Sony BDP-S300... | Answered on Sep 11, 2019
In most cases, the issue might be with the Java content on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6495&mdl=BDPS300
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Try another disk, see if it plays. Try the one that won't work in another blu-ray player if possible. I tried to watch a disk I got at a redbox rental, it fouled 2 dvd players, but took it to a friend's house and it played just fine. When I went to return it, it wouldn't go back into the redbox machine. I had to try at another redbox machine and it took it. So could just be a problem with that disk.
Sony BDP-S300... | Answered on Jul 11, 2019
It's not possible to change the region code in the Blu-ray Player.
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
Region A: North America, South America, U.S. Territories, Japan, South Korea, Taiwan, and other areas of Southeast Asia
Region B: Europe, Africa, Middle East, Australia, and New Zealand.
Region C: Asia (except for Japan, Korea, Taiwan, and other areas of Southeast Asia)
Sony BDP-S300... | Answered on Jun 13, 2019
i ordered a dvd of boxing, but it wont play on my dvd, it says blue ray what is that?
lens is defected get a tech to repair it or buy a new set.good luck.
Sony BDP-S300... | Answered on May 28, 2019
Update your fireware.
Pavtube Blu-ray Ripper is the best Blu-ray ripping software, is capable of ripping both Blu-ray discs and standard DVDs to your required HD or SD media formats.
Sony BDP-S300... | Answered on Apr 03, 2019
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Sony BDP-S300... | Answered on Apr 02, 2019
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Sony BDP-S300... | Answered on Nov 30, 2018
Hey jude06,
In order to play Blu-Ray discs, you must unfortunately own a Blu-Ray player. Neither HD-DVD players nor Progressive Scan/Upconvert DVD players are capable of playing the discs, and standard DVD players are not able to recognize information on the discs due to how they are constructed.
Please keep in mind that there are always a number of options available to you, should you consider purchasing a Blu-Ray player. While the average asking price with many retailers for stand-alone Blu-Ray players is between $300.00 and $500.00, you can typically obtain an internal Blu-Ray drive for your computer for considerably less. Additionally, the Playstation 3 may also be a viable alternative - the current 40GB model not only plays Blu-Ray discs, but also has the added perk of being a video game console for around the same price as the average stand-alone Blu-Ray player.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Sony BDP-S300... | Answered on Nov 12, 2018
The most common problem with blu-ray discs in blu-ray players like the BDP-S300 seems to be related to firmware issues. You can download the latest firmware from the Sony website here. Once burned to a disc on your computer you load the disc into the blu-ray player to update it.
I hope that helps.
Sony BDP-S300 Blu-Ray Disc Player Logo
674 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
vizio tv code sony blu ray disc player
  • Televison & Video
