I have a Sony STR-DG800 receiver and I'm trying to program the remote(model RM-AAP008) to work with my cyberhome. I can't find any controller codes for it. Any ideas?
P.S. On cyberhome's website(the European one) in the FAQ they listed this:
The codes for such remote controls are determined by the manufacturers of the remote controls, not by us. We just can name you the codes of the company all4one, because this company communicates the codes to us. The codes are as follows:
0714, 0816, 0874, 1019, 0794
Should none of these codes work, we unfortunately cannot help you. Please directly contact the manufacturer of the remote control.
Thanks for the link, but I don't think it will work. It looks like it's some file to program a "Home Theater Master MX-500" so that it works with a "STR-DG800" receiver. Problem is I'm trying to program the remote from the receiver to the CyberHome.
I think there is not going to be a solution to this problem. Just not enough documentation anywhere. I appreciate the thought though.Thanks for the link, but I don't think it will work. It looks like it's some file to program a "Home Theater Master MX-500" so that it works with a "STR-DG800" receiver. Problem is I'm trying to program the remote from the receiver to the CyberHome.
Tengo un DVD ciber home 300 y busco un control remoto para este.
¿ Qué marca u modelo me sugieren?
Saludos
Miguel A. Hernandez M.
Saludos
AnonymousMar 22, 2014
whats the codewhats the code
HAVE TRIED ALL LISTED CODES AND ATTEMPTED TO RETRIEVE CODES OWNER DOES NOT HAVE ORIGINAL REMOTE CONTROLHAVE TRIED ALL LISTED CODES AND ATTEMPTED TO RETRIEVE CODES OWNER DOES NOT HAVE ORIGINAL REMOTE CONTROL
You can't post conmments that contain an email address.
This should do it;
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=mx500&db=devices&br=sony&dv=receiver&md=strdg800&kw=STR-DG800&st=1&ar=&dt=&so=&pg=1&file=mx500/systems/barry-linton_m53.zip
Hope this helps:)
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control - 1. Press menu 2 times to get to system info page 2. In the system
info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that
says IR and indicates you the channel your remote control one is
configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds. 2. then press the '1' button on the numeric pad of your dish remote 3. then press the '#' button on the numeric pad of the dish remote 4. then press the 'record' button (red dot button - stores setting) 5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
http://www.dvdremotecontrols.com/Mfrs/Sony/SonyAudio/RM-P341.htm is a website for finding the Original remote for your str-d1015 your remote model is RM-P341 and the link above will direct you to information on the remote as well as where to buy it and how much PLUS A PICTURE :-) hope this helps you
Saludos
whats the code
