Started last time immediately, nothing has changed in wiring. Battery is charged but ignition is only chirping. will not turn over motor
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
SOURCE: 75 mercury boat motor not turning over
you have one of two problemsyour starter brushes are sticking or your solenoid is going bad next timme it happens take a hammer and lightly tap the starter if it turns over your starter is going bad if you try this repeatly and nothing then you have a bad solenoid they are not expensive if you do not want to tap the starter then just replace the solenoid the best way to find it is follow your main battery line to motor where it stops and breaks with two posts and then the hot goes to the sarter take a picture of it so if you need to take it with you u acn see where the wires go oriellys probally will have it is round and you battery will go to one post and the hot to the starter will go to the other there will be to little posts on it as well one to the key switch and the other is a groud
SOURCE: Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
SOURCE: I am replacing an ignition switch in a boat. I
cant send wiring diagram -too big for this site-did try-and have one for mercury in line series
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
SOURCE: I have a 2000, ficht 225 evinrude motor that won't
I have the same problem--let me know if you find a fix! [email protected]
