Netflix works fine on the compaq laptop which is connected to the tv with a SVGA cable. Have tried changing the resolution but still get invalid format on tv screen.
SOURCE: i cannot get my netflix movie to play on my vizio flat screen tv
There is a key that looks like a monitor, It may have to be used with a FNC or CTL key (look at the color - matches the FNC or CTL color. It should go laptop, tv out, both, laptop, tv out, both etc as hit it.
SOURCE: connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: I have a Panasonic Blu-ray
Hello - The following link to the Panasonic support website will give you step by step video
instructions on how to setup Netflix --
http://www2.panasonic.com/consumer-electronics/support/How-To-Guides/Video/Blu-ray-Disc-Players.75416.H#ts
Hit the "Blu-Ray Disc™ Players - How to Register with Netflix" on that page and everything will be detailed.
Happy Viewing,
Mikeywaf
