FORGOT PASSWORD FOR ADMIN TO NAVIGATE WINDOWS SO I NEED DIAGRAM CHART TO LOCATE JUMPERS TO RESET PASSWORD
Forgot dell admin password? I also met the same trouble with you, but i used Smartkey Windows Password Recovery to help me to reset forgotten windows password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
SOURCE: jumper location motherboard blade 2, dell latitude x300.
The password is not on the battery it is in the volatile memory.
The battery supplies the power to the volatile memory to make sure it retains its settings.
If you have removed the Cmos battery and when you put it back the machine still has a password then the password is written into the non-volatile memory and cannot be re-set that way.
Get a hold of someone with ERD Commander and they will drop the password off in a couple of minutes
SOURCE: Forgot Admin Password for Dell Latitude D620
i have same problems in my same lattude d620
pls help to break admin password.
my id is [email protected]
SOURCE: I can't reset the cmos or hdd password
You'll need to contact Dell Tech support for a master Password for that system 800-624-9896 (USA) verify you are an authorized user of the system, then they will assist with a master password
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
