SOURCE: Peavey PR15-D Powered speakers, Power on but no sound.
Check for impedance ( resistance) in ohms on the speakers disconnected from the circuit using a volt/ohm meter. I think the woofers are 8 ohms and the tweeters are 8 ohms. Also check for bad solder joints where the jacks are soldered to the circuit boards.
SOURCE: No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
