Cracked screen cannot be repaired. It has to be replaced by a new one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
If you haven't already done so, go to the Setup menu (the wrench). Under CSM/Setup Menu, select Full.
Now go to the Custom Settings menu (the pencil). Find Auto off Timers. Long will display image review for twenty seconds. Custom will let you set it for as long as ten minutes.
I can't remember but there should be a button with the name above it No. of Copies press this then you will be able to enter 1-99 copies. The energy saver you can adjust within the menu to longer or not come on at all. This will be in your manual.
