Microwave Ovens Logo
Posted on Dec 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Damaged inner seal tape on whirlpool microwave door window
How do I remove/replace the inner seal tape on my whirlpool microwave model mh6140xkq1 inner door window?
  • jomitchell Dec 15, 2008
    Thank you, but my question is this: Does the old damaged seal tape just peel off. Is this seal tape just a thin piece of plastic?
  • kiwibird2009 Mar 27, 2009
    where are the pictures? I could not separate the panel. Please help! Thanks.
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on Dec 08, 2008
William Miller
Level 3:
Answers
9179
Questions
Helped
4481728
Points
21747
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
  • William Miller
    William Miller Dec 15, 2008
    Sometimes it's thin clear tape, sometimes (especially in the case of seal tape) it will be a little thicker and like foam tape.
    If it won't peel off easily, heat it up with a hair dryer, being careful not to get the dryer too close to the plastic because it may melt.
    You may also use a solvent like WD-40, penetrating oil, or even cooking oil to help loosen the adhesive.
    Just be sure not to get it in visible areas.
    Instead of spraying the solvent on the parts, spray it on a soft cloth and dab it onto the parts and let it set a few minutes.
    Then when the tape is off, use a 50% or 70% isopropyl alcohol to make sure the parts are squeaky clean and dry.
    We're
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2087
Points
It is called Seal Tape and you can order new ones online at partselect.com
How do I replace the inner door glass on a neff C67M70 microwave
Not easy. All microwave repairs should be done by a professional. Oven doors are easy, but they make microwaves harder because they need to be sealed and checked for radiation leaks. Traditional ovens are easy, microwaves aren't.
https://www.google.com/search?q=replace+the+inner+door+glass+on+a+neff+C67M70+microwave
Can I replace the door seal on my Whirlpool Integrated Microwave?
Gaskets are available, but with all microwave repairs, I would recommend using a repair technician unless you are confident of doing it properly. The door should be checked after all repairs for microwave leakage.
https://www.repairclinic.com/Shop-For-Parts/a6b5c21/Whirlpool-Microwave-Gasket-Seal-Parts
https://www.google.com/search?q=whirlpool+amw505ix+microwave+door+seal+replacement
1helpful
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
2answers
I have a whirlpool microwave model GH7155XKT. The door cover is cracked badly and I ordered and received the replacement part. I can not figure out how to replace the Choke or Cover
Hi deflcsw,
I see you need a manual on how to replace you Microwave Door.
I checked the Manual does not have info regarding how to replace the Door just the Bulb and the Filters in it see here .
To be able to get information on how to replace the Microwave door you will need to contact Whirlpool 1-800-253-1301, you may need the Model and serial number so they can provide you info about the door replacement over the Phone if the door cannot be replaced by you then they can reffer you to a local center near your address for the replacement to take place or possibly get soemone out to replace it for you.
I hope this helps.
Have a nice day, Thank you for choosing Fixya,
mvincentc
2answers
How to replace door handle on whirlpool microwave model MH2155XPS-0
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. A replacement part number for the model you have listed is 8169738.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
22helpful
Replacing a whirlpool microwave door handle! got the new handle..how do I open the door up to screw the new handle on?
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
MH6150XMT0
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can usually find helpful exploded view diagrams (and order any other needed parts) by entering your full model number here.
When you peel off the old seal tape, it's best to heat it up with a hair dryer and work slowly so it will all come off in one piece and to minimize the amount of adhesive that has to be solved and scrubbed off.
1helpful
3answers
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL ([email protected])
2answers
Microwave oven door removal
First you have to tell why you want to remove the door. The door seal is important to keeping the radiation from excaping and is not recommended to fool with it.
Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
