Oh, there it is in the second problem you posted. Intel 945GCZ,
Hmmm, lemme see.................Junction 1 Header 3,
Dunno, the wonderful(?) motherboard manual doesn't state it.
The Southbridge chip is an Intel 82801 (ICH7)
Right next to the 4 SATA connectors. Are talking about that jumper block with 3 pins, next to it?
LEAVE IT ALONE!
That is the BIOS configuration jumper block.
Has three pins. The outline around number 1 pin is a square.
The outlines around pins 2 and 3 are circles.
Pin 1 is towards the outside of the motherboard. Towards the I/O area.
Should be that the jumper block is on Pins 1 and 2, for normal operation.
Testimonial: "This is what I need for the jumper definition. Still have having power on issues. I second question I posted. Thanks for the help on this one!"
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
Hope this helps
Nothing. That is because you forgot to state the motherboard manufacturer, and Model Number. Jus sayin'.
