SOURCE: how do i get my mouse to connect
The power switch is located on the bottom of your mouse. To connect/activate: a) press & release the link button on your receiver. b) press & release the link button located on the bottom of your mouse.
SOURCE: Targus PAWM001 Mouse - How to connect it to my laptop
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
SOURCE: change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: i installed targus AMW1602 wireless mouse, was
Replace the mouse battery and check also the wireless connections between your computer and your mouse.
SOURCE: i have a targus wireless mouse MODEL:AMW1603EU the
Did you ensure the ON/OFF Switch is set to ON? Did you also try replacing the batteries, then pressing the connect button on the receiver followed by the connect button on the bottom of the mouse?
