Acts like loose circuit. tap on cb fixes for a while
SOURCE: tv picture shrinks to one small line across the middle the screen.
resolder vertical output ic pins
SOURCE: tv keeps flat lining and shrinking picture
If this is a crt tube tv. Your vertical ic is loosing its connection with the board. Better to quickly resolder it or reflux it with a new lead. Before the IC fail for good.
Seems to be loose land etc. as if you tap circuit board problem comes and goes. Picture draws in on sides and goes back out if tapping on Circuit Board. When failing image/picture looks as if 110 volt power is down to about 70 or 80 volts. Bright pictures seldom fail but a darker picture and sides draw in and top down but less.
