Samsung DMT300RFS Builtin Dishwasher Logo
randy lowe Posted on Apr 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung dishwasher dmt 300rfb wont drain and is humming
Brand new dishwasher, used 5-6 times. At end of wash cycle, started delicate light started blinking. I tried to cancel and drain, it only hums, then the light starts blinking again. I pulled the unit out, disconnected the drain hose to check for kinks, etc. None noted. There should not be anything clogging the hose as it is new and I rinse my dishes. Water drained freely from the hose. I have turned the power off at the breaker box to "reset it", this has not helped. I have then tried to start a wash cycle, but it only hums, then the delicate light starts to blink.
deton8 von Splosion
Level 3:
  • Samsung Master 3,342 Answers
  • Posted on Apr 22, 2017
deton8 von Splosion
Samsung Master
Level 3:
Answers
3342
Questions
6
Helped
928933
Points
54123
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
2answers
My samsung dishwasher has a constant buzz that occurs during start up and lasts through all of the cycles. I saw where there is an electrical noise filter and did not know if that could be the cause.
No a noise filter is a different kettle of fish. That stops electrical interference noise from affecting your television, radios and electrical devices.
The most likely source of the hum is the start capacitor on the motor, or the motor itself.
https://www.google.com/search?q=samsung+dishwasher+start+capacitor
This has a different idea
Humming or Grinding If your Samsung dishwasher makes noise when starting that sounds like a low hum, it's part of normal function. The motor makes this sound as it operates throughout the wash cycle. However, a dishwasher making loud humming noise or grinding sounds could mean that debris is caught in the drain pump.
Samsung Dishwasher Making Noise? Follow These Tips
This says the drain pump, but the drain pump only runs to empty out so it wouldn't do it all the time.
https://kitchenbuds.com/dishwasher-guides/samsung-dishwasher-making-grinding-noise/
Lots of other ideas and videos
https://www.google.com/search?q=samsung+dishwasher+humming
My Samsung Dishwasher keeps flipping cycles during the course of its run. I set it to "normal" and it ends up on "delicate". Dishes seem to be clean, but are still wet after the 2 hour run time. Help...
I'll bet that Delicate light is flashing, which is actually indicating an error. You didn't mention your model number, but in most Samsung dishwashers I'm familiar with, that light indicates a Drain Error. You may have something hard caught in the impeller of your drain pump, or you might have a bad ECS sensor. In any case, it's time to call a dishwasher repair technician. For Samsung dishwashers, I recommend calling Sears Service (1-800-4MY-HOME or 1-800-469-4663).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
2answers
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 • Dishwashers
1helpful
2answers
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
9helpful
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
Regards,
BElectric
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
