Completely dead no power to the control panel, lights or anything else. Twoo fuses check ok.
Someone needs to follow the voltage into the unit--- The voltage goes to fuse and then to inverter that drives the unit---fyi if unit is not real expensive a repair may not be practical----use some precautions if not familiar with this kind of appliance.
If you cannot find it look for a company who does authorized repairs--they will be familiar and have access to the parts---reason I asked was Inverter is usually over 100 if bad---someone may be able to trace it up to keyboard and to inverter to see what is happening---If you have a meter and it is unplugged check the power cord from end to end first.
could be the issue or the magnatron or the inverter may have got it--when doing warranty work we used to be safe change both.
SOURCE: ge spacemaker microwave
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE Spacemaker XL1800 (JVM1860WD 002) Stoped Working.
The control panel has built-in surge protection, and the high voltage probably tripped that. It will have to be repaired, which we do nationwide for only $39.95 postpaid. By rights, I would say the electrician should be the one to see to the repairs, including removing the control panel assembly to send in for repair. We have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 Please let us know if you have any other questions.
SOURCE: GE microwave oven - just stopped stopped working
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
SOURCE: My GE microwave JVM1860 is
One of the most common problems with Ewave microwaves is a loose blade on the cooling fan, causing the magnetron to overheat.
At this time looks like the magnetron, the magnetron TCO and the fan
blade have to be replaced.
I think it's worth fixing. It's about $650 new.
I found a thermal fuse on top of the magtron burned out.
