SOURCE: water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
SOURCE: My towels always smell sour...it doesn't matter
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
SOURCE: Cabrio won't spin
F then 50 flashes when the motor rotor
position sensor (RPS) senses no rotation.
➔ Does basket turn freely? If not, make sure
bottom shipping pack has been removed.
Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control,
by analyzing drag on the basket, detects a
suds-lock condition, and is steady on while the
control then runs a mini-clean out cycle. If the
clean out cycle is unable to correct the
over-sudsing problem, the cycle ends and Sd
flashes in the display. This may signify:
➔ Load is bunched or twisted around agitator.
➔ Excessive detergent usage.
➔ Basket cannot engage during drain step.
➔ Mechanical friction on drive mechanism,
not allowing basket to engage.
