Is there more information you can provide? Examples, once I click the memory stick in, nothing happens on the screen with windows version? What size is the memory stick? Is it new from the store? What appears on the screen? If you open 'my computer' do you see it as a choice? If so, what happens when you click on it? Does it recognize it but not load the data off the stick?
The laptop does either not find the hardware (hard drive and mermory etc) or the motherboard has pooped... however... try removing the battery and also the hard drive and memory and then put it all back again. it often solves the problem.
Plug in the ipod,double click on my computer and see if it shows as a drive.If so and you want this turned off,you can do it by opening itunes and going into the settings and disable hard drive mode.
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Evesham Nav-Cam 6200 turns on then sticks at the front page
( navigator, MP3 Photo, Setup) and won't go any further, tried
hard and soft reset but nothing happens. can you help.
hy you have a hardware problem and you have tree reason for this :
1.- the batteries don't have enough ampere to start hdd motor this is happening when you charge it whit your computer and not whit apple charger.
2.- you have short whit your lock and hear plug check this first
3.- hdd cable are broken because of the vibration off the hhd
