20 Most Recent Apple Ipod Nano Second Gen. Green (4 GB) MA487LLA MP3 Player Questions & Answers
If you want to erase the contents on the device, you can connect it to itunes on your computer and erase everything from itunes.
Apple Ipod Nano... | Answered on Jan 31, 2017
I have the same ipod and had the same problem - I ignored itunes and the computer and went to "real player" and treated it like an mp3 player and in real player you pick your music you want to burn to a cd but go to "device" column and change the destination from burning to your internal cd burner to the external drive which is the ipod and it downloaded perfect! hope this helps
Apple Ipod Nano... | Answered on Nov 11, 2016
For unlock instructions, click on the Apple help site:
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Apple Ipod Nano... | Answered on Feb 02, 2015
Have you tried replacing the cable you use to connect your iPod to your computer?
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
Apple Ipod Nano... | Answered on May 10, 2014
Hi candyparker9
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apple Ipod Nano... | Answered on Mar 23, 2013
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apple Ipod Nano... | Answered on Aug 28, 2012
recognition problem. Computer is not recognizing your device when plugged in. If "so," then it can be a cable hookup problem. To find out if your computer is recognizing the device, look on your devices list within the computer.
Apple Ipod Nano... | Answered on Aug 27, 2012
Normally, you cannot sync an ipod to more than one system at a time. You have to wipe out all the songs that it previously occupied before so that it can accept songs from a new computer.
It is quite normal for all the songs that were previously on it to be flushed out when you connect it to a new computer.
Now to the main issue of getting errors on every song, this is not normal.
The only solution to this is to restore the software using the itunes program.
This will help you format the memory of the device thereby removing any sort of system errors or malfunctions in the system of the device.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Apple Ipod Nano... | Answered on Jan 21, 2011
there is no way to do it without restoring. So if you want to do it the right way. Then here you go. that is not a problem follow the steps below. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the
device (or restore from a backup). If you restore on a different computer that was never synced
with the device, you will be able to unlock the device for use and remove the passcode, but your
data will not be present Follow the steps that i have outlined below. If this does not completely help your situation
please let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the
following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to
manage its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a
PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal
features again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please
note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your
combination. If you can't unlock your iPod and you don't have access to the primary computer,
your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great
day.- Midwest-tek
Apple Ipod Nano... | Answered on Oct 22, 2010
I have read that if you connect it your computer, and using the
itunes, to sync first then eject it will reset your code to where you
can get into your device.
Not totally sure.
Apple Ipod Nano... | Answered on Oct 05, 2010
that is not a problem. follow these steps and you wont have a problem. unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
Apple Ipod Nano... | Answered on Aug 26, 2010
that is not a problem and i will be glad to assist you. If you cannot remember the passcode, you will need to restore your device using the computer with
day.
day.
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Good luck.
Apple Ipod Nano... | Answered on Jun 25, 2010
Apple Ipod  Nano Second Gen. Green (4 GB) MA487LLA MP3 Player Logo
107 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
fix screen ipod white
  • Audio Players & Recorders
