Need instructions on how to replace this part.
Remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
does the agitator need to be removed also
