That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
Just tried the fuse box deal and it worked.... Thanks so much for your idea and great thinking... Now I can wash these smelly dishes lol
Thanks so much for this wonderful Idea... I just flipped the switch on the fuse box and it works fine... Green light started to blink and now dishwasher is working perfect!!! I messed with this thing all night long and was so excited that your idea worked... Thanks again...
Thanks it worked for me today 11-7-17
awesome , worked like a charm
Had to say thank you for this tip. Had tried turning off at electric by pulling the plug but didn't work. Fuse box and holding in start button worked a treat. Saved me a new dishwasher! Merry Christmas!
Thank you! This worked in 2022-had to do a second time-I may have missed the two blinking lights the first time though.
I holded Heat key but it didn't worked. Then I just started pressing random keys and holded start key with Heat key together. Then pressed Heat key for 8 sec and finally light turned off.
SOURCE: Frigidaire Energystar dishwasher will not start.
Press and hold the "heat dry" button until the light turns off. It is in lock mode.
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
SOURCE: frigidaire dishwasher pld2855rfc stuck on
Hi.
To reset a Frigidaire dishwasher you have to press a sequence of buttons three times. This is familiarly called button dance
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry, High Temp Wash.
If you don't have a heated dry then do the same button dance using "drain off" or "air dry" instead of heated dry.
If that does not work, contact the manufacturer on number listed on use and care manual, as the appliance may have a defective timer control.
Regards.
SOURCE: Frigidaire dishwasher will not dry the dishes.
Sorry, but I must start at the beginning. Is the "heat dry" switch on. If so is the unit a 220 volt or a 110 volt? You can tell by the plug end, if it plugs into a regular outlet type than it'a a 110 volt . If it has a special plug outlet (large black or large gray) then it'a 220 volt.If it is indeed a 220 volt go to the main house electrical box and try to locate the dishwasher breakers. swithch it, or them off and on. Then try your unit again. If it's a 110 volt then you've got internal control malfunctions of some sort. I'm not a Frigidaire certified techy, But I'm sure if you hop on the phone to the service dept. someone will hand you a solution in seconds after you descibe "exactly" what is going wrong.Thank You ,very much, Dana
SOURCE: My Frigidaire 24 in. FDB1050RE Built-in Dishwasher
I am having the same issue. This might be a common problem.
