Dryers Logo
Posted on May 03, 2012
E56-002 error from dryer - Frigidaire AEQ7000ES Dryer
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips
Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect...
Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu...
Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ...
Videos for E64 Error.
2answers
I have whirlpool dryer dscx 80114 problem is displaying error f19, how i can handle it pls help me
please power cycle your dryer and check for the error again. Ensure that your the lint has been cleaned out of your dryer before checking for the error again. If still having issues, please check any initial document that has tips/trouble section to help overcome that specific error.
Thank you.
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 • Dryers
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
1helpful
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
