The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Traduire cette pageThe F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Traduire cette pageSears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
Traduire cette pageBy unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
This would indicate you have a lint build up somewhere in your exhaust system. The best way is to disassemble the unit and completely clean the unit. Also remove the exhaust hose and make certain it is clear all the way through and that the exit door is not blocked closed or plugged inside. I normally do this annually and then use a long brush to clean monthly to maintain a safe, functioning unit.
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
It is most likely the water pump on the washing machine. Check the hot and cold hose and make sure there are round gaskets on the inside of them and that they are tight on the hot and cold valves.
Also check the drain hose that it doesn't have any holes in it and that the hose is far enough down into the drain . If all that's ok, it's your water pump.
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
