SOURCE: ASUS A832-SLI Deluxe Display Errors
neckbeard
remove the memory and gently clean it very well and then connect it back to motherboard. if got long beep then memory damage.(replace memory) if got tree short beeps, clean the video card and connect it after cleaning if got same beeps ( then replace video card) thats only only things. Good luck.
SOURCE: 2 short bit continouse
Try reseating the memory first. then if that doesn't work, try different known good memory. Also try reseating the CPU. make sure this is no dust in the memory slots and the CPU slot as well. Make sure you only have the connectors from the power supply going into the motherboard and don't have any drives hooked up so this way you can make sure its not a drive causing the beeps.
If you have a video card reseat that as well. If after all of this you have no luck, then the motherboard is bad.
SOURCE: laptop won't boot up.
it looks like your rams are broke down. can you write your notebook model /mark down ?
SOURCE: continuous short beeps on power up.Then shuts down
enter bios setup and check the temperature of your mobo and cpu if it's above normal and also check the cpu fan's speed if theres no problem with these three then try to remove all the expansion cards you have then reset the memory modules if the beeping continues try a different PSU and memory modules.
SOURCE: My laptop is beeping 3 TIMES. One long beep 2
according to this page:
http://www.computerhope.com/beep.htm you have the following error:
"Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information"
the solution is this
http://www.computerhope.com/issues/ch000607.htm
