We have a GRP257STS (Australian, discontinued model) Side by Side LG fridge that has an ice dispenser and a Home Bar. It is making a single beep noise (different to the door open alarm) which sounds at variable intervals, sometimes a few times a minute, sometimes every other minute or sometimes once every 5 minutes (all while nobody is touching the fridge). This has been going on for a few hours today. It happened previously and went on continually for 3 days then stopped. The fridge is 3 years old, out of warranty. Is there any troubleshooting we can look at doing ourselves? Thanks kindly
SOURCE: Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
SOURCE: I have a 6 y.o. whirlpool fridge wbm 46 model
Hi The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
I powered it off at the wall for 10 mins and now it has stopped.
Hi. I have the same problem. It is a problem with the temp controls, I am having the same problem for a few months. I will try the fix. Thanks /
