My Frigidaire Dishwasher never seems to dry my dishes,Whats up with that. Please can anyone help me. Thanks, Raymond.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Heating element bad
Set the sanitize button and they will dry
SOURCE: Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
SOURCE: Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
SOURCE: we have a FGHD2433KB1 model
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things...
Bought new spray arms online and installed them inminutes...now the thing works like new...
However I have also found that if the heating element goesbad then that also can mess things up bad...
So I would buy new spray arms, and also check out theheating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
MY LG NEW DISHWASHER DOES NOT DRY THE DISHES AFTER
THE WASH CYCLE IS COMPLETED
the dishwasher does not dry the dishes
have the same dishwasher and same problem
Its not drying my dishes
Dishes are not drying
