PC Chips M957G Motherboard Logo
Duane Myers Posted on Apr 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No video output to the monitor - PC Chips M957G Motherboard
SALMAN NASEER
Level 3:
Genius:
  • Master 1,011 Answers
  • Posted on Apr 19, 2012
SALMAN NASEER
Master
Level 3:
Genius:
Answers
1011
Questions
Helped
309642
Points
3022
Dear,
first of all, check if there is any beep sound coming from the board.
Because beep sound represents the error as its code.
After this, check it accordingly. If non of above then board can be problematic. Check it by the way by removing all removable devices like hard disk, cd/dvd rom, floppy etc and let the system ON only for motherboard.
best of luck!
Monitor won't stay on
how is the monitor connected to the computer? what connection type is the monitor is it VGA or HDMI . What format is the computer video output is it VGA or HDMI. Also you may have two video outputs on the computer. Sometimes the motherboard vga output is disabled so that a much better video plug in card can be used which has its own video output port.
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
1helpful
2answers
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
My monitor says "no input signal" every time I put it on. I have checked all the wires and connections and they seem fine. Any suggestions?
Starting from the monitor and going to the video connection to your computer, make sure everything is connected and undamaged. If your video card has more than one output, try switching the cable to the other output. If neither is working, and the monitor works fine from a different computer, then its the video card, otherwise its the monitor. But again, before dropping any money on a new monitor, try a different cable, and try switching the cable to the second output if there is one. A video card is definitely cheaper than a monitor.
1helpful
How to connect 3 LCD monitors to a computer
Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
resolutions of up to 1600 x 1200 Allows for effortless multitasking
1helpful
I have 1widescreen 28'' monitor and want to add two 22'' monitors
Connect one monitor to the second DVI-output port.
Connect one monitor to the S-video output port.
Right-mouse-click anywhere on your desktop "wallpaper".
Click Properties.
Click Desktop.
You should see 3 icons -- one for each display.
Drag-and-drop the icons so that their position
matches the physical layout of your 3 monitors.
Click "extend my desktop onto this monitor".
2answers
Monitor comes on a boot then goes black
check video card it may be going out
No S-Video nor RCA Video output to monitor
First, you've checked and the monitor will display other sources plugged into the same monitor input?  And you've tried plugging the receiver into another TV?  Otherwise all I can tell you is that the receiver does not convert.  So if you want to see S-Video on your monitor, you have to input S-video.  If you want to see RCA output, you have to input RCA.  Best of luck.
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
