Connected the USB cable and can't display the computer desktop on the projector.
SOURCE: it just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
SOURCE: my vpl cs5 projector is 5 years old. It has no
The problem I can confirm is either one of two faults in the main power supply section.It is either one of the double diodes in the TIP type casing which has gone short, or the other most common is the main oscillator IC in the primary of the power supply.Please check the double diode first as the main IC is about twenty pounds very expensive.Please also note change the three capacitors in the primary power supply section whilst you are at it.kind regards John Williams www.jvsvisual.com engineer to the stars.
Don't know why the usb hookup didn't work. I purchased a Mini DisplayPort to VGA adapter at Fry's and went in that way. It auto-configured and lit right up.
