Anything gray WILL print, as well as all colors. Anything black will NOT print. have tried new cartridge, cleaning printhead and aligning printhead, nothing works.
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: Kodak 5300 not printing colors
Kodak told me to take the printhead off and reseat it several times, which I did. I then deep cleaned it, calibrated it, and replaced the color cartridge. It didn't solve the problem. Kodak will replace the printhead for free, and after I return the defective one, will send me a free color and black cartridge. Very nice service. I've been very happy with the 5300.
SOURCE: kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
SOURCE: Replaced printhead and ink cartiages on a Kodak ESP.3
I had my esp3 stop printing black also. I bought new cartridges even tho' I knew the ones in the printer were at least half full. Still not printing black. I finally called Kodak support and got a tech who was the first tech from India who could speak English well. He was very helpfull but in the end he told me he would send me the printer head because that was the problem. My printer was not used for about a month and the head dried up. The tech said that printer must be used about twice a week and the best way was to print the test by using the 'Scan' and 'Copy' at the same time. There was no sense telling the tech this is a huge flaw in the printer as he must have been hearing this for a long time. After I received the new printer head it prints fine. This is an absolutely huge flaw in this printer. If they can't make a different style of head for this printer these will stop being used................. So if you have the ESP3 (I don't know about the other models) and don't use it often the head will dry up and you can't clean it (according to the tech I talked to). Kodak should send these free for the life of the machine in my opinion.
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
just remove the head printer and wash with warm water and lett.t dry and replace.t
