SOURCE: Samsung HLP5063W DLP
no you do not need a bulb you will need to have the color wheel replaced.
SOURCE: hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
SOURCE: tv will not stay on
If the lamp light is not on, then the TV is flashing because of overheating or because of a fault.
Try first unplugging the TV and leaving it unplugged overnight, this will drain power completely and may solve some problem.
If the TV keeps having a problem, then there is a fault.
Many units have more than one fan (one for lamp, one on ballast, one on board). In that case ensure that all fans are working.
If the problem is not a fan, then parts can cause the problem are ballast board and DMD board.
In that case the parts must be tested before replacement.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts.
SOURCE: picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
SOURCE: No picture on a Samsung HL-P4663W, trouble lights confusing...
The most common blink code for the Standby/Temp LED is the Temp Sensor and or Actuator Board. You can confirm which on by jumping the CN106 connector on the Actuator board. If the set works now, the Temp Sensor must be replaced. If it doesn't work, the Actuator Board would need to be replaced. If you are not familiar with the chassis or electronics at all , I do not recommend trying to fix it, call a professional. Don't take the chance of damaging it further.
I hope this helps,
Skyassoc
