Garden Logo
Krystal Stout Posted on Apr 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2 year old Husqvarna YTH2348 Makes a horriable sound when blades are engaged. I didn't hit anythng just started making sound so I shut it down. Checked under it and inspected belts, everything
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Apr 12, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2134458
Points
13357
Remove the belt and feel each pulley for a bad bearing
5 Related Answers
Anonymous
  • Posted on Oct 16, 2009
SOURCE: Zts has no Power when Blades Engaged
check the coils
I had the same problem 1 coil went out.
I replaced both to save time and money later
Anonymous
  • 226 Answers
  • Posted on Jun 01, 2009
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Anonymous
  • 405 Answers
  • Posted on Dec 23, 2008
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
heres2maine
heres2maine
  • 84 Answers
  • Posted on Apr 15, 2010
SOURCE: Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Anonymous
  • 3911 Answers
  • Posted on Jun 03, 2010
SOURCE: blades making a bad noise
Well I would say you have a bent blade, a blade has a loose connection to the bottom of the mandrel, or a mandrel bearing is going out. Visual inspection will reveal much, just look under the deck. A bad mandrel may appear to have "runout" when viewed from the top while spinning as contrasted with a good mandrel. Viewing the one in the center while deck is working is going to be a challenge. If you decide to replace a mandrel, do yourself a favor and take a picture of the deck belt before you take it off so you know how it goes back on.
Engine Start
Hi Art Weiner...
Check you seat safety switch...it may be faulty
Bud
1helpful
Hi I have the YTH2348, the problem i'm having is i'm getting a bearing sounding squeal when i have the blade clutch engaged. I noticed before it starts to squeal I'll hear a like loud click and...
if its an elect pto then it sounds like its in the workings of the pto pully
also if its a manual lever that you move to engage the belt, it could be the pully that tightens up the belt and turns the blades, most of the pullies are greaseless and prettymuch throw away
3helpful
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
1helpful
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
8helpful
2answers
1helpful
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
