Turns on then clicks to standby mode no pitchure at all
SOURCE: samsung s5053, will not turn
Ken, did you ever find out what was wrong with your set and have it repaired?
I have the same "clicking" problem when first turn on the TV. First, it took about 30 secs clicking (came from the relay) then came on ok. The wait time gradually increased up to a few minutes before it comes on. Then, the power button was flashing blue light when the TV is off, but then came on ok after 3 - 5 minutes. Now it finally has no power at all.
I checked the stand by voltage at pin 10 of the CN804-1 connector and get nothing but a going spike voltage up and down on the multimeter. I noticed that one blue ceramic disc capacitor (the disc type, not the can type) was cracked and some black burned spots around it. May be it is the problem?
B+ over voltage protection (OVP), unit goes to the standby mode then
displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
Have you set the output voltage correctly?
