20 Most Recent
Samsung PS42S5H 42 in. HD-Ready Plasma Television Questions & Answers
Will not turn on can hear relay? clicks right LED flashing other solid
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung PS42S5H...
Answered
on Feb 05, 2015
Samsung ps42s5h
There is some short circuit inside one or more circuit boards inside your TV. It need a thorough check up It is a skilled work. If you wish to get more details, surf the
following link. There are over two thousand and four hundred posts. All are
related to television and other domestic electronic equipment service help. You
can get a solution there. Type in the brand name to your device to its search
box, can be located at the top right of the display window.
Samsung PS42S5H...
Answered
on May 11, 2013
I have whats called "red
You will need a small philips head screw driver and a Digital Volt Meter for this.
Unplug your set and take the back off
Plug the set back in and turn the set on
Now with your meter find the test point on the power supply that says VS. If you cannot find it, you can measure it at the plug of the board.
Make the sure the voltage matches the sticker that is on the panel. It will say VS. If it does not match, find the VS adjustment pod and adjust the voltage to match the sticker. If the voltage already matches, it is safe to raise 10 to 15 volts. If the picture starts to clear up, you are going the right way, if it gets worse, you need to adjust the other way. If it doesn't change at all, then odds are you have a bad panel.
Samsung PS42S5H...
Answered
on May 23, 2011
