Showing error code 13 but would like to know if there is a list out there of all the possible error codes . Thanks so much for a response , RJ
SOURCE: Juki DDL-8500
The DDL 8500. is a high quality, single needle, straight stitch, industrial machine. If it is still in a good condition and the present owner is prepared to guarantee it for at least 3 months, it is a good buy. Retail for app. $790.00 new.
Good luck
SOURCE: I can't find the User's guide/operating manual
Here you go.
https://www.sew4less.com/product/3197/Juki_DDL8500_Instruction_Manual
Good luck
SOURCE: Missing manual
Hi I hope this helps. These are United States contacts. Thank's, Jeff http://www.juki.com/contacts.html
SOURCE: i need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
SOURCE: my juki machine ddl-8500-7 is locked how can I
hi there
can u check one by one
1 - loose screw for needle bar clamp and turn the wheel by hand.
2 - from down remove the finger for hook and turn machine pully maybe some thread insaid the finger.
3- loose the four screws for upper main shaft and turn the machine pully by hand.
best regards
ashraf abozid
[email protected]
Checked all fuses and disconnected all connections and reconnected . Now the error code is err 7 . My circuit board has a white button and three below it . Is there a need to reboot or initialize this board before it will shut off error warning and possible run the motor? Thanks so much for any response .
displays. Thanks
