Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
