Lets not get ahead of ourselves. Why did you change the fuse. If you put it on bake, the bottom element should come on, If you put it on broil then the top should come on. Does anything work on this oven. I think I would check the voltage at the receptical (outlet) where the oven plugs in. It should be 240 volts. Is this just an oven, has anyone been adjusting the clock or timer.
