Whirlpool single oven, I think it is the model listed above.. turn the oven on, but no heat! In the oven is a grill element at the top, when selected this DOES heat up ok, so it is just the oven aspect. The light to show that oven is heating DOES come on, also the fan also comes on, just no heat. Any suggestions please??? Sick of cold food and grilled food now!
Diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
after cleaning the oven...not heat??
